Hot potato
Started by fishdds, November 29, 2003, 04:06:06 AM
javacody
fish, you can use a 46 and 10 ohm resistor in series to get 56 ohms. Series looks like this:
A--------=====-----------B A ---------=====------------B
Where A of the first resistor goes to the board, B connects to A of the second resistor and B of the second resistor goes to the board.
There is a snippet on wiring pots here:
http://www.diystompboxes.com/cnews/FAQ.html
Scroll down a bit.
fishdds
Hey guys, I'm trying to add a pot for volume, to match output and such.  If I use a 100k ohm linear or audio, I get no sound for much of the travel of the pot, and then a very narrow usable range at one end of travel.  What value pot should I use, or is that not the problem?
Travis
no, you're right.  It sounds like the value of the pot is the problem.  Instead of 100k (100,000) use a 500 or 100 ohms pot.  It just needs to be one thousand times smaller.
Good luck.
