Whipped up a '70 Fuzz PCB....
Started by Bucksears, November 29, 2003, 06:23:32 PM
Craig V
Built and tested.
Sounds EXCELLENT.  Very warm FF sound.  The PCB was really well done, probably the best I've ever etched and drilled.  Very good spacing.
Did anyone who's tried it have slight pot wiring problems?  I wired everything with the 1 and 3 lugs backwards, so I redid everything the correct way, and the mid and vol pots were still backward.  It's probably just me... I tend to screw simple things up.
Thanks for the PCB.  It was an easy build.
ps.  I used BC108B's.
