which delay to build...? PT-80, or Rebote 2????
Started by nightingale, December 23, 2003, 10:30:45 PM
nightingale
man, i love delay!
i am putting together a smallbear order:
which circuit should i build? is one easier to debug than the other? which one performs better?  the pt80 uses 18v, is this an advantage?
curious,
~ryanS
be well,
ryanS
www.moccasinmusic.com
Joep
The Rebote is nice, I build one and I like it.
The PT-80 has more (expensive) components an may be a more difficult build, the soundsample are really promissing thou...
I'm working on a PT-80 PCB right now.
Good luck,
Joep
moosapotamus
I haven't built either of the Rebotes. But, I luv my PT-80.
~ Charlie
moosapotamus.net
Joep
The Rebote I mentioned about is the Rebote 2 from Tonepad
The Rebote 2 is an improved version of the Rebote. If you are going for the Rebote, use version 2.
Regards,
Joep
