V/R
Started by petemoore, September 27, 2004, 11:57:51 AM
I just get tired of twisting pots...and need a third hand...so another quest begins...
 What about...a widget that increases or decreases in resistance as you press harder on it...kind of like a peizo pickup for guitar or...well you get the idea...I'm always searching [to no avail] for the 'other thing' that can replace say a 100k or larger pot.
 Soemthing that could go up and down in resistance automatically...yes, I suppose I should just get the LDRs with the R range I want...
How about a foot rocker pedal??
puretube
FSR = force sensing resistor...  (under the black pad).
strungout
R.G.: lol
Ah! I was just thinking of suggesting to scavenge a Playstation controller or something like that. The newer ones have pressure sensitivity.
"Displaying my ignorance for the whole world to teach".
"Taste can be acquired, like knowledge. What you find bitter, or can't understand, now, you might appreciate later. If you keep trying".
toneman
hire a roadie(?)
must B able 2 push buttons and
flip switchs with the blink of an eye.
your eye....
dr
....do like I did-save the conductive foam from your IC purchases-stack them with a copper washer on top and bottom (with wires soldered to them of course!)works like a "force sensing resistor"....or poor man's pot......you can stack quite a bit of it between there!......I did this to a pedal I built and can control four of five parameters......the more it is compressed, the lower the resistance goes......
