GEAR PINION for wah pot. Where can I get one!?!?!?
Started by BillyJ, January 10, 2004, 01:18:01 PM
BillyJ
Driving myself mad searching for these.
What I need is to find gear pinions that have a set screw for these solid shaft pots I have dug up.
They must exist but where. All I can find is replacement pots.
Gonna try emailing all the experts on wahs out there but thought someone here might have the answer I seek.
Many thanks!!!!
gez
The Tone God
Most common wha pedal pots use a a gear that is intended for "D" shape shafts. If you have a solid shaft you have a few options.
1. Drill out the gear to fit the shaft. A tough thing to do correctly. You will then need to adapt some mechinsm to hold the gear in place. Glue, set screw, C clip are options.
2. Make your solid shaft a D shaft. Grinding is probably the easiest way but once again tricky. You have to becareful.
The other options is make your own gear/mechanism or find a D shape pot shaft.
Andrew
BillyJ
Yeah I will give them a call on Monday.
I have one of their older clarostats and the gear is for a semisplit shaft that uses a clip. The pot would have to have that type of split and also a groove for the clip. These have neither.
What I really need is to find the same gear but for a solid shaft with a set screw or two even. I founf some local but they are too large in diameter.
Thanks for the lead though I will give them a call on Monday.
Any other leads appreciated as well. Thanks!!!
BillyJ
Hey ANdrew,
Thanks. I had thought of trying to hollow out a gear and drill the pot and gear with a hole and putting a small rod or cotter pin type of thing.
I was hoping to at least find gears that I didn't need to hollow out.
I have some Centralab pots that are like this. I've even tried to get the gears off of them but no luck yet....
I figure I could handle drilling a pot shaft but grinding one or a gear seem a bit too tricky for me.  I don't seem to do well with grinding at all.
Well I know what I need probably exists it is just a matter of finding them...
I'll keep poking around something will turn up..
Thank you all!!
Aren't those wah pots with the 'D' shafts also a lerger diameter?
 This is a tricky one I'm going to poast about it in a new thread I think...maybe I have a trick that'll make it easy...
if you start with a bobbin just the right size made out of an easily machinable yet sturdy material, you could mark where the cog grooves would be by rolling the bobbin across the pinion [flat gear] which has paint on it, then cut/ file out the grooves, alot of work but it's the only backyard way Ive never tried.
Ansil
you can use plaster of paris to cast a mold from an existing one. be it working or not.  and then goe from there. and cast you a replacement piece for a couple of dollars when you think of hte cost of the plaster.  and the time involved.   i might have one laying around soemwhere let me see.
actually i do have a snarling dogs one lying around i know.
Mike Nichting
Hey Billy,
I have an original gear with set screw from an old wah. I will send it to you. I have your addy and it will be with the rest of the stuff.
peace,
Mike N.
"It's not pollution thats hurting the earth, it's the impurities in the water and air that are doing it".
Quoted from a Vice President Al Gore speech
Ansil
hey mike.   could you make a mold of if before you send it off.  that would be beneficial to all of us diyers. i no longer have a place to make my own molds. but if someone cast a mold and sent it to me i could make some duplicates.
