Grounding unused opamps in duals and quads
Started by Robin, January 17, 2004, 11:55:43 AM
Robin
Mike Burgundy
to avoid any weird effects that *may* occur. It's very likely nothing will happen if you don't, but it is possible that "floating" opamps cause problems like oscillation etc.
smoguzbenjamin
The Tone God
Mr. Murphy and M. Nature have a habit of showing up when you don't want them to. Its a "better safe then sorry" policy that any good designer would adopt.
Andrew
Robin
Ok, thanks for the replies.
I guess I was looking for more specifics than "it stablizes the opamp". Take the LM324 (please); the datasheet shows bias circuitry common to all amps, but so what (if no signal is involved)? I 'm guessing capacitive crosstalk wouldn't be an issue.
I agree that it's probably good preventative practice to ground unused opamps on a PCB. I just get frustrated when I'm breadboarding a simple single opamp circuit and all I have handy is a dual. Should be no big deal to leave it hanging in a prototype, yes?
Rob
Paul Perry (Frostwave)
On a breadboard, there is no problem leaving an unused op amp section floating.
Brian Marshall
what parts do you ground???  I always ground the non inverting input usually through a resistor (i read somewhere a long time ago to do that dont remeber where) and tie the inverting and output together, but dont send it anywhere.
puretube
if input not grounded, and output floating, the opamp shows almost infinite open-loop-gain: amplifies the smallest stray signal it picks up to (almost) rail-to-rail "volume". This can cause (HF) oscillation for that particular unused opamp, which can go stray into the rest of the circuit.
