What kind of component is this?
Started by Triffid, January 28, 2004, 10:54:16 PM
Triffid
I recently scrapped an old radio I had laying around and actually found some cool parts that have used in my boxes.  I found a bunch of these components and I don't know what they are. I think they are some sort of capacitor, but I don't know.
The top of the box says "150nK".  The label on the pcb I got it of says "CC24", "CC25", "CC26", etc...
Thanks for your help in advance
brett
That a 150nF MKT (film) cap.  Similar in many ways to a greencap of the same value.  The value is always written (often in nF) on the top, together with a code for a voltage rating (K in your example).  They're top quality components.
Brett Robinson
Triffid
Awesome, thanks... that would be the same thing as a 0.15 mf right?
Thanks again
brett
Yep.  1nF = 0.001uF (nano is a thousandth of a micro)
Brett Robinson
zachary vex
if you find units that look like that and they have no 'n' after the value, they are in pF with the following rules:
153 means 15 with 3 zeros following, or 15,000 pF
101 means 10 with 1 zero following, or 100 pF
100 means 10 with zero zeros following, or 10 pF
blabj
thanks for that last piece of knowlege, now i know the value of the caps in my parts box
cheers
Callum
www.By-Default.co.uk :D
