Pulsar transistors
Started by Kaiowas, February 08, 2004, 04:47:38 PM
Kaiowas
In the tonepad's pulsar project the transistors are 2n5088, can i use the 2n3904 instead?
"De quién era la piragua?!"
Kaiowas
toneless
I think 2N3904 is ok but try BC549 or BC550,too.
Keep in mind that the you may have to reverse the pinouts...
Nick
bioroids
Hi
2N3904 work great, I used them for this circuit with no problems
Luck!
Miguel
Eramos tan pobres!
The pulsar uses a transistor as a sort of simulated resistance to ground, exactly the same way transistors are used in the Doctor Q and Baseballs filter sections.  Just about any garden variety NPN will work fine there: 2N3904, 2N5088/89, 2N4401, 2N2222, etc.
Gringo
I used bc549c at first and it worked great, but then i took em out to make an obsidian/highway 89 (haven't decided yet) and rteplaced them with some trannies from a computer monitor.
Anything with a gain over 300 seemed to work just the same. Below that gain the LFO didn't oscillate at all.
Cut it large, and smash it into place with a hammer.
http://gringo.webhop.net
Kaiowas
Hi guys!
Thanks for the info, i just finished the pulsar with 2n3904 (all of them) and it sounds great!!
Thanks.
Kaiowas
