BA6124 envelope filter
Started by ExpAnonColin, February 10, 2004, 10:27:10 PM
ExpAnonColin
NOTE- I have NOT built this circuit.
Any problems/recommendations?  You could get quite interesting results by changing the various frequencies of each of the "stages", but you'd have to keep in mind if it was doing highpass, it'd only go as high as the highest stage, and same for lowpass, if you know what I mean, since all the lights go on and not just one.  You could also create quite a nice compressor with this chip (coming soon.)
-Colin
mattv
So you'd have one filter for each LED? Very interesting...  :)
Peter Snowberg
That's a very cool idea. I like the idea of a 'posterized' envelope filter.
One question... When are you going to build one? ;)
Any source for the BA6214? I suppose you could always adapt an LM3915 or LM3914 too.
Great idea though! I like it!  :mrgreen:
Take care,
-Peter
Eschew paradigm obfuscation
Tim Escobedo
tomtom
QuoteWhy reinvent the wheel?
http://stomper.hp.infoseek.co.jp/my_schematic_pic/fifth%20element.gif
I have this one on my computer for a while, still I can't see how it may sound.
Any idea ?
Tom[/quote]
Paul Perry (Frostwave)
Since the current to ground via pin 4 will vary depending on how many leds are lit, perhaps that could be used to vary the impedance of a transistor, like in some wahs based around a twin tee filter.
ExpAnonColin
Quote from: Tim EscobedoWhy reinvent the wheel?
Because I was unaware that the wheel had already been invented.  My bad.  I'll probably build one this weekend.
-Colin
Elektrojänis
Wouldn't that be a bit different than Colins idea in the first post? Colins idea seems to be to vary the levels through filtters with static cutoff frequencies. this other one has bandpass filtters where the cutoffs vary. Did I misunderstood sething?
Both should be interesting though.
Btw. Even though the filters in that fifth element one are all tuned for different cutoffs (by different caps) I think it would be interesting to have them tuned to same cutoff with the cap selection. After all... They are not moving at the same point at the same time... Right?
