what would make the switch pop after it wasn't?
Started by marrstians, February 17, 2004, 03:50:32 PM
marrstians
i built a ts808 clone... it was fine with no pops... i guess the pull down resistors were doing their job... but all of a sudden it started poping... loud ... and i don't know what's causing it... i checked cont. on the pulldowns and they're still connected... what next?
Samuel
Is it possible you've got a problem with input/output caps? Check for DC voltages around the Input and output caps...maybe one of them is leaky, or has a cold joint.
Mike Burgundy
There's a LOT of things that couls be causing this. Low-voltage caps with a DC wiring mistake, electrolytics wired wrong-way-round, lubricants in the switche bleeding into the switch contacts....
Try a good-grade DPDT hand switch with alligator clips (parralel the FS with this) to make sure the pop isn't coming from the footswitch. If it's not, the problem's very likely o be a leaky cap or a lack of DC blocking in general.
marrstians
it was my output cap... i replaced it and it worked... i guess that shows me not to use scavanged parts...
Gringo
Maybe that's what's happening to my pulsar... :twisted:  :twisted:
Time for some surgery.
Cut it large, and smash it into place with a hammer.
http://gringo.webhop.net
