56pF in TS...?
Started by wulla, March 09, 2004, 02:03:21 AM
wulla
Can anyone tell me of the 51pf cap (im using 56pf btw) is in the signal path or not in tonepads TS??. I cant find any other cap this value other than ceramic right now. If I know it isnt in the signal path anyway then ill go ahead and put in. thanx :0)))
Peter Snowberg
Go ahead and use it. :D
That cap is only to remove ultrasonic content and 56pF is more than close enough. You will never hear a difference. 56 might even be better. The tolerance on those caps is probably +/- 20% so a cap marked 51pF might be anywhere from 40pF to 60pF anyway.
Take care,
-Peter
Eschew paradigm obfuscation
Oliver
Hi,
i build one circuit with 100p Cap and two anti parallel 1N4004 Diodes.
Works very good and gives a very rough Sound, not so Sweet, sounds
more crunchy.
I think you can go to 200p Cap (put it on a socket and try out)
Rock ON!
Oliver
Only dead Fishes go with the flow... >-))))-°>
wulla
thanx guys! ill do that. However, im still wondering if it is actually in the signal path or not? thanx again :0)
Peter Snowberg
Quote from: wullaim still wondering if it is actually in the signal path or not?
Yes and no. :D
It's in the feedback loop of the opamp so in a sense it's in the anti-path. Whatever makes it through the cap gets subtracted from the signal coming out of the opamp. I guess strictly speaking it's not in the direct path, but it's still in a direct path when you consider the opamp has two inputs.
Take care,
-Peter
Ge_Whiz
I guess it's true to say that it's not in the AUDIO path, since it is effectively open-circuit to audio frequencies. It is in the signal path for RF noise and effectively shorts out the latter, which is its purpose.
Manolo Dudes
It's funny but most 47pF ceramics I have measured with a LCR meter are in fact 51pF capacitors  :roll:
a.k.a. "Calambres" in www.pisotones.com
