Started by lightningfingers, April 05, 2004, 06:40:57 AM
lightningfingers
hey all, does anyone know a schematic for a pocket amp that uses a regular 741 opamp?
cheers in advance :mrgreen:
U N D E F I N E D
RDV
The best you can do with an opamp is a headphone amp. Here is a site where you can find info on opamp headphone amps and such.
http://www.headwize.com/
Regards
RDV
smoguzbenjamin
If you want a headphone amp, I say use an LM386 or JRC386 ;)
Paul Marossy
An LM386 is a lot quieter than a 741 is. You would probably be happier using an audio amplifier type chip, unless noise doesn't bother you...
RDV
Actually for a headphone amp they(the chaps @ Headwize) recommend the Burr/Brown OAs for them; low noise, wide freq. response.
As for a 741, build a Dist+!
Regards
RDV
lightningfingers
Quote from: RDVAs for a 741, build a Dist+!
yes...i think i will
thanks!!
U N D E F I N E D
