Help with this Schematic
Started by John Lyons, April 07, 2004, 11:12:22 AM
John Lyons
Hey there.
I can't figure out what +Vb means on this schematic.
+9 would be the battery positive tab but +vb stumps me. Maybe + volts bias? If it's bias where does this bias originate? I'm trying to build this as a 2 band Parametric eq pedal but there are a couple "missing" pieces in the puzzle.
Also how does the resistor and cap assortment  (mid left of schem) tie in  to the rest of the schematic?
Thanks in advance
John
Basic Audio Pedals
www.basicaudio.net/
smoguzbenjamin
Vbias is usually 1/2 of V+ or in this case 4.5v.
Post the link to the schematic and I can help you better ;)
Mike Burgundy
Look in the DIY FAQ (link above) and read the "Power Supply - What is V.R., V.B, VREF, 1/2V+ etc" bit. This will also give you an inkling where them resistors+cap arrangement tie in.
There should be a point marked Vb between the two resistors (resistive devider - cuts the voltage in half) and a couple of points in the schematic with the same label.
Rule in schematics: if points are labelled the same (A, B, Vb, +, ground, etc) they're tied together in real life.
hih
puretube
