One last question
Started by jjucius, April 25, 2004, 08:59:25 AM
jjucius
I am putting together my jimi in a box, now i have three effects, vibe, fuzz and octavia. the vibe gets 15v and the rest get 9v i am going to tap off of the vibe (15v) to the outher two through a 7809 rect. now my question, can i (or should i) connect all the grounds from the boards so i have a single ground? or should i connect each one?
Thanks for all your help. and thanks to aron for the switches. i will try to post pics when i am done. again all of you have been a great help. :D
Joe
By the way, next project.......Marshall Tube Amp :shock:
smoguzbenjamin
Sure you can use the same ground. Isn't the ground of your amp also connected to the ground of your guitar and pedals? ;) All grounds are connected.
jjucius
Thanks. just drilling the box and should be done today.
I know it sounds a little morbid, but I think it would be cool to have that.
jjucius
Total cost for putting this thing together is about $150 and a lot of labor  :shock:  :D  :D  :D  lot cheeper than buyin them :D  the name is not going on the box (too much respect) still trying to come up with one, any ideas?
