Cleaning up old boards, connections and enclosures
Started by Phorhas, April 22, 2004, 04:13:20 PM
Phorhas
Hi guys,
I heard a few time of some kind of electronic components "wash" or cleaning solvent or something in the area, so... how
DO YOU clean old ugly,corrosion infected, rusty FX and the such...?
Electron Pusher
Peter Snowberg
I use an old toothbrush with denatured alcohol, water, and/or xylene/acetone in multiple steps. Alcohol is semi polar, water is polar, and xylene/acetone are non-polar. Between these solvents and some heavy scrubbing you can wash most gunk away and not leave solvent residue. I would avoid using any solvent that contains oils as they will leave residue and stop the alcohol or water from being used after.
Good luck,
-Peter
Eschew paradigm obfuscation
Phorhas
Electron Pusher
crawler486
In my experiences, a room mates toothbrush is way better.
Gilles C
Alcohol, for prototypes.
This,
http://www.mgchemicals.com/products/4140.html
for the boards I want to look good and that I know I won't have to touch again.
Gilles C
Gilles C
