Here's some mods for the differential distortion
Started by brett, April 26, 2004, 08:50:28 PM
brett
Hi.
On the weekend I spent some time messing with the differential distortion.  A couple of simple changes gave a circuit with more punch and distortion than the standard circuit.  It also has a neat thing where it sort of "clamps down" on the early part of the envelope, then lets the volume swell a little and the harmonics blossom as you move into the decay/sustain part of the envelope.  Hard to explain, but I think most people would quite like it.
The components that are different to (or additions to) the standard circuit are in large type on this schematic.
cheers
Brett Robinson
Kool Name...I tried to build a Differential, a long time ago, but I never figured it out.
 Nice job on the schematic, I like the shapes in it.
Could you post some Pin Voltages for Me?
 I can't seem to get it working.
 The PNP's would be facing opposite to Q1, if built on perf but 'like' the schematic?
 I have the PNP Emitters 'on the top', where the arrows are.
 My voltages are strange for the PNPs in an amp position.
 Any Ideas?
brett
Hi Pete
The approximate voltages are-
2N3904
C = 4.6
B = 0.8
E = 0.2
2N3906s
C = 0V (actually, it will be maybe 0.1V for the one with the 1k resistor)
B = 4.6V
E = 5.3V
Probably the main thing is to have the 2N3094 collector and 2N3906 bases somewhere near 4 to 5 V.  I agree that the operation of the 2N3906 pair looks weird compared to the usual common emitter amplification stage.  But it does work.
Good luck.
Brett Robinson
I'll work on it again tomorrow, and see if I can get something to report on!  It's Bedtime for Bonzo !
rocket
if you move the output (including the 1k resistor) to the 2nd transistor,
input and output of the total circuit will be in phase rather than shifted by 180 deg , which might be useful for some purposes.
the sound should not change.
you can even have two output, phaseshifted by 180deg.
brett
That's a cool idea.  Now, if you took those two signals and cancelled them, I suppose you'd be left with some distortion products, probably including some octave-up.  Hm... Might have to try something with that.
Anyway, it's not a bad distortion.
Brett Robinson
