led mounting
Started by ryani, May 11, 2004, 01:30:23 PM
ryani
I really like the way the led's on zvex pedals are mounted with no bezel and the tip of the led just sticking up out of a hole in the enclosure.  Does anyone know of a good way to secure led's this way? Thanks
Ryan
markusw
I suppose he mounts them directly to the PCB. But there are also small rubber sockets you might want to use.
dosmun
A glob of Silicone or Hot Glue or similar products should do the trick.  Also make sure you drill the hole so the LED fits in snug.
