Need some help with The Thunderchief
Started by Fernando Aguirre, June 03, 2004, 07:05:20 PM
Fernando Aguirre
Hi!
I have finished the thunderchief project from runoffgroove and i used j201 fets.
I adjusted the trims to correct values but i find that one of the trims can´t go lower than 8.3v. I tested the trim and it works ok, can it be a defective fet? any advice?
Thanks in advance.
Fer
Brian Marshall
what is the supply voltage????? sounds like the source of the fet isnt seeing voltage
brian
Fernando Aguirre
The supply is a 9v battery and the fet is receiving it.
I don´t know what it can be.
Brian Marshall
what is the voltage on the source??????
that other link looks interesting... i havent built one yet though.
RDV
From Gary @ R.O.G.
QuoteRemember that jfets are highly variable. You may find some that will not bias correctly, even though it is a J201 from the same lot. Always buy more than you need and sort until you find ones that will work.
_________________
Gary
Regards
RDV
B Tremblay
Along with the trimmers, sockets are highly recommended for this reason.
Are you certain that the respective trimmer is wired correctly?  Is there any voltage fluctuation at the drain of the FET while turning the trimmer?
B Tremblay
runoffgroove.com
Fernando Aguirre
Problem solved, i found i made a mistake with the value of a resistance and put a wrong one.
Now it is working properly and the fets are correctly biased.
It sounds really nice! it is lacking some gain but i think it is because of the battery.
Very nice and warm sound, very very Tube like.
Fer
