Old Japanese 6 band eq pedal repair
Started by hamandles, October 12, 2019, 06:13:55 PM
hamandles
PS Anyone know where is a good place to get replacement fader knobs in the UK?!!
Good to see you got it working.
QuoteE: 3.68v
C: 9.31v (fresh battery!)
B: 3.91v
Doesn't quite match Rob's predicted voltages but seems plausible.
It's close enough to normal.  It would take a schematic to judge any finer details.
QuoteTested it again with some white noise and I could definitely hear the 800hz control making a difference now. I wonder if a slightly wonky looking capacitor could have been to blame
You never know what you find when you dig around fault finding.
tubegeek
Quote from: hamandles on October 18, 2019, 06:12:08 PM
You might have good luck making your own little tips out of a product sold here in the US for making soft handles for hand tools etc. It's called Plasti-Dip here, basically a gooey rubber paint that hardens into a medium-thickness glossy skin. The tips in your photos look like they were made some sort of similar way. Otherwise maybe two layers of shrink tubing, with the inside layer left long and folded over, and the outside layer trapping the folded part underneath.
This faders are too close together for "normal" fader tips to fit, I think.
Another possibility - google "Top hat switch tip telecaster" - these might be small enough to fit that layout. The faders look like they have a similar metal end as the Tele switch.
https://www.homeoftone.co.uk/products/telecaster-top-hat-switch-tip?variant=35679304778
https://www.taydaelectronics.com/electromechanical/switches-key-pad/toggle-switch/toggle-switch-handle-cap-black.html
not in the UK, not fader knobs, but they might do the job. cheap, three colours, if they don't work, stick em on yer toggles!
" I will say no more "
willienillie
Quote from: tubegeek on October 20, 2019, 02:03:34 AM
:icon_eek:
Those are huge, much larger than Strat switch tips, which still might be too big to fit this pedal.
tubegeek
Quote from: willienillie on October 20, 2019, 01:14:54 PM
:icon_eek:
"Some modification necessary" perhaps....
hamandles
Some interesting thoughts here, thank you.  Yes, the tele pup selector would be too big, although the whole unit is a little bigger than I expected.  I guess I expected a Boss sized unit,  but this is longer and wider.
I may have a go with some plastidip or shrink wrap - good tips!
