supply drop down?
Started by JimRayden, July 15, 2005, 05:33:21 AM
JimRayden
Is it normal that when I connect the 9v battery to the Ruby amp, the multimeter says 2,5V across the battery?
Any possible known miswiring?
Jimbo
puretube
...or an empty battery.
JimRayden
I have piles of these 9V batteries at home and I always have lots of trouble finding a full one. And yes, for this one the battery is about 8.2V. The dropdown happens when I connect it.
Jimbo
JimRayden
Here comes the wierd stuff... I connected another battery (8,6V) to it and when I turn up the volume, I hear some beautiful oscillation. :) I actually like that smooth-sounding oscillation but I want it to amplify my guitar, not oscillate. :\
Jimbo
MartyMart
Jim, does the battery get "hot" whilst connected ?
If so, there is a short somewhere....
I had a similar problem with a VB 4.5 volt power conection recently, it
was reading less than 2 volts !
There was a "drain" (short) from an opamp connection causing this, once fixed
the VB became normal again.
Marty.
JimRayden
yea but the wierd thing is that one battery drops to 2V and the other starts to oscillate. Wierd...
Jimbo
JimRayden
Maybe it's because I changed the volume pot from 10k to 5k?  :?
EDIT: Or maybe because I changed the 1,5M resistor to 1M and 3,9k to 3,3k? These were the closest values I had. Could they be the problem?
Jimbo
Nope, those alterations won't matter about the V drop thing.
