custom AB box... switch channel and change speaker...
Started by Mistymountainhop, July 10, 2004, 04:14:12 PM
Mistymountainhop
to make this on one box:
A. would 16/8 ohms blow a DPDT switch?
B. wiring wise, could i put both negative feeds on the same middle pin ona  dpdt switch and have a normal wiring for the top row of pins ona  dpdt...
PICTURE;
okay, on 1 - nothing
2 - earth i think on channel change circuit
3 - live on channel change circuit
that makes a normal channel change with the DPDT
okay, then on the second row
4. clean speaker (in this case vintage 30) + (posative)
5. vintage 30 and hi gain speaker - (negative)
6. metal speaker +
would this work... so...
ahh, balls... after doing all that just realised, thats just gonna link the 2 speakers up :/ how could i make this so i could put a lead from the amp into the stomper... then 2 leads out and that switch selects the speaker?
is this possible? it should be in theory... if the switch could take the ohmage that is: but how would that be encorporated between...
lead   Switch   leads
from            to
amp             speakers
