Limiting an unknown resistor to a specified lower resistance
Started by John Egerton, August 20, 2004, 11:35:31 AM
John Egerton
Hey guys...
I'm still on my quest to make a touchpad resistor using the synthstick design and I have done it...
However at present the maximum resistance of the strip is unknown (no multimeter yet).
I was wondering ho best to go about limiting the maximum resistance of the strip to 5k?
Thanks....
John
Save a cow... Eat a Vegetarian.........
I don't know the layout or implementation but it seems a 5k resistor would do that.
Rich G.
Right, a 5k resistor in parallel will limit the value to 5k.
John Egerton
I see...
So this will allow me to use the strip to vary resistance and the resistance will never exceed 5k? Even if the strip was greater than 5k to start with?
do i put the resistor in parrallel with the input or the output of the variable resistor to achieve this?
Mike Burgundy
if you parallel two resistors Ra and Rb, the end value of the combo is
1/R=1/Ra + 1/Rb
If you think about this, this means that:(let's assume Ra is 5k and Rb is unknown)
-the only way R can reach 5k (the value of Ra) is when Rb is infinite (1/R=1/Ra+0)
- maximum resistance will always be lower than Ra, or Rb for that matter. If Ra=Rb=5k, the two in parallel will yield R=2.5k
You should parallel it *from input to output* to use your terminology.
Hope it helps.
