Millennium bypass PCB layout?
Started by markr04, September 14, 2004, 08:57:39 PM
markr04
Is there a PCB layout for the millennium bypass? I'm going to make one if no one else has one to share.
Pardon my poor English. I'm American.
D Wagner
There is this one for Version 2.  http://www.diystompboxes.com/pedals/pcb/MIL2.jpg
I remember seeing one for the new version C somewhere, too.
Derek
markr04
Quote from: D WagnerThere is this one for Version 2.  http://www.diystompboxes.com/pedals/pcb/MIL2.jpg
Derek
Thanks!!
From the little reading in the .pdf on the Geofex site, it looks like the 'C' version is only 'better' for people who can't find mosfets easily. If that's the case, and since the mosfets are $.10 at the shop near me, the Millennium 2 would be just fine. Am I understanding that correctly?
549
what number of low leakage diode? :D
martinbertrand
I my opinion, The millenium bypass is made easier on perfboard.
About the diodes, Mr Keen posted a quick trick a while ago. I've always had trouble making mine work using a 1n914 for the high leakage diode and the base-collector junction of a bipolar transistor. I have instant success when I place two 1n914 for the high leakage and one 1n914 for the low leakage one. This WORKS instantly.
Martin Bertrand
www.lesdeloreans.com
markr04
Quote from: martinbertrandI my opinion, The millenium bypass is made easier on perfboard.
Hi Martin. Thanks for your reply. I'm curious... are the two 1N914 for high leakage run in series?
martinbertrand
2x 1n914 in parallel for the high leakage.
Martin Bertrand
Torchy
Use a BS170 (ST70A mine are marked) .... voila, no need for low leakage diode. Made a bunch so far and none worked with the extra diode, all worked great without it.
QuoteUse a BS170 (ST70A mine are marked) .... voila, no need for low leakage diode. Made a bunch so far and none worked with the extra diode, all worked great without it.
The low leakage diode has never been necessary for operation. It's there for protecting the MOSFET from static-ey electric fingers.
