MN3010 (Mark Hammer, please)
Started by Thomas P., October 05, 2004, 10:07:58 AM
Thomas P.
Hi!
Do you know if the MN3010 equals the TDA2110?
god said...
∇ ⋅ D = ρ
∇ x E = - ∂B/∂t
∇ ⋅ B = 0
∇ x H = ∂D/∂t + j
...and then there was light
I can't verify the pinout, but this says it does, at least functionally: http://www.vego.nl/7/7_005.htm
I think I'm going to have to keep a closer eye on stock lists, now!!  I always look to see if a distributor carries the TDA2003, TDA2030 and such (power amp chips), but I never thought to look at such lists for BBD's.  I guess it's a mistake to focus too much on the MN prefix.
Thanks!!
P.S.:  You will note that virtually all of the links for the TDA2110 that pop in Google are German.  Lucky for you, I guess.
Thomas P.
Thanks, Mark!
There is a supplier here in the town I live which sells obsolete semiconductors. I came over it while searching for the MN3010. I made a request and they have a stock of 80 for 24â,¬ each.
A bit expensive - but also very obsolete :wink:
god said...
∇ ⋅ D = ρ
∇ x E = - ∂B/∂t
∇ ⋅ B = 0
∇ x H = ∂D/∂t + j
If 24 Euros lets you make a clone of a pedal which could easily cost you 10 times that much, that's not a bad deal at all.
