About Freqs
Started by nero1985, October 12, 2004, 08:01:24 AM
nero1985
Based on the Graphic EQ on my recording software this is the FREQ im trying to get
*Freq(Hz)*   *Level*
600           -24dB
1110          +20dB
15000         -24dB
this is pretty much boosting the MIDS but how u say it in KHz? (1110)
im trying to get it with GEOFEX's graphic EQ...
brrt
I guess you're searching for this:
*Freq(Hz)* *Level*
0.6 kHz   -24dB
1.11 kHz +20dB
15 kHz    -24dB
Mike Burgundy
what are the other parameters - such as Q? What does the curve look like?
There's a huge sonic difference between a mid-boost at 1k, and a general boost, with hard cutoffs at 600Hz and 15kHz..
nero1985
i really woundt care if i have to cut or leave the lows and highs where they r as long as i get to achive a "TELEPHONE" like mid boost
this is how the curve looks like
http://albums.photo.epson.com/j/AlbumIndex?u=4241292&a=31434379&f=
go there and the last file is called "untitled.bmp" thats the graphic
niftydog
for telephone sound, you basically want a brick wall high pass filter at 300Hz (perhaps even higher to simulate your phones crappy speaker) and a brick wall low pass filter at 3kHz.
Telephones don't "boost" the mids, they CUT everything else.
BTW, +20dB is a hugh amount of boost, do you really need that much?
niftydog
Shrimp down the pants!!!
tube man in a kilt
ya, the filter i made doesnt even go above 0db.
Signature:
This is a block of text that can be added to posts you make. There is a 255 character limit
tube man in a kilt
ya, the filter i made gives 20db of mid boost in the 600-1000hz range.
Signature:
Hal
Quote from: nero1985Based on the Graphic EQ on my recording software this is the FREQ im trying to get
*Freq(Hz)*   *Level*
600           -24dB
1110          +20dB
15000         -24dB
KHz = KILOhertz.  To convert from any base unit to any kilo-unit, divide by 1000.  5000 meters = 5 km
etc.  Multiply to go backwards.
