Which switch for Rangemaster input cap mod? DPDT On-on?
Started by brianh, October 17, 2004, 04:20:59 PM
brianh
Mark,
Could you explain what you meant above by "yes, OR no" ?  Did you mean "yes" if that accomplishes the three values I want, "no" if it doesn't accomplish the values I want?
Like I said, I I'm still not sure which caps are "working together" with each of the 3 positions on the switch.  Assuming my last wiring diagram could be used!
I think when the leftmost "on" is selected, it's all three caps:
1/C1 + 1/C2 + 1/C3.
Past that (if I'm even correct about that), I'm still a bit lost.
