Wall wart specs for Sopht amp?
Started by smashinator, December 03, 2004, 11:54:48 AM
smashinator
It's likely that I just missed the details somewhere, but I just searched the sopht threads on this forum and read through the Sopht site again, and I don't see how much current the wall wart needs to be able to supply.  Is 1 amp sufficient, or will it need more than that?
People who say it cannot be done should not interrupt those who are doing it. - George Bernard Shaw
http://pizzacrusade.blogspot.com/
slajeune
Hi,
I am using a 12v 1.6A wallwart.  If you can find a bit beefier (14v > 1.2A), it should do the job nicely!
Thanks,
Stephane.
smashinator
Thanks for the info!
Just so I'm clear, I would use a regulator chip to get my voltage down to 12v, right?  Or do the tubes suck enough current that the voltage will drop on it's own?
Luap
I See Stephane already got this one (while I slowly typed)!:oops:
Also ...probably a good idea to measure AC voltage on any wart before you power up- the one I tried had a 12V ripple! --bbbBBBZZZzzzzzz!!!!
You don't want to go much more than 13V on the heaters, how much the voltage will drop really depends on the wart. Measure it under load- they very greatly from whats on the lable.  Lower than 12V is ok, it just won't be as loud. (splitting hairs)
---------Sopht amp current--------
12u7=150mA(h) + <1mA(plate) = 151
12k5=450mA(h) + 35mA (plate) + 85mA(SC-grid)= 570
Current for 12k5 version = ~721mA
12u7=150mA(h)+`1mA = 151
12al8=550mA(h) + 1mA (plate) 35mA(plate) + 85mA(SC-grid) =671
Current for 12al8 version = ~822mA
Luap
....a,       ...Ok,            ...never mind, forget it, you would understand anyway.
(repeat) -Flipper "brainwash"
smashinator
