Tremolo with variable waveshape control
Started by Hevimies, December 18, 2004, 11:33:54 AM
Hevimies
Is there any others than EHX pulsar re-issue, and where can I get the schematic?
Or is it possible to mod, for example, an older EHX pulsar to get the variable waveshape control?
ethrbunny
Try the tremulus lune at http://commonsound.org. Lots of interesting mods for that proj.
--- Dharma Desired
"Life on the steep part of the learning curve"
ExpAnonColin
It's a matter of the LFO.  Take just about any tremolo circuit and you can pull  out the LFO and put in one with a variable waveshape.
-Colin
puretube
check out some synth DIY sites for inspirations... ("LFO");
be aware however, that LDR-based trems might not
be able to follow fast abrupt waveforms exactly, volumewise.
(the PULSAR "re-issue" schematic is not publicly available).
Hevimies
The tremulus lune looked pretty cool... I think I'm going to build it, with few mods and a millenium bypass.
Or then I'll change the LFO of some other trem. I don't know yet...
Thank you guys!
