Oscilloscope pictures of the Sopht amp
Started by slajeune, December 22, 2004, 03:25:08 PM
slajeune
Well, after what seems like forever, I finally got around to putting an Oscilloscope on the Sopht amp. Click here to see the gory details:
http://www.sopht.ca/index.php?s=26
Basically, I get a very clean first stage, some compression at the 2nd stage and power tube distortion. The output is a whopping 31mW which is expected from these tubes at 12V.
BTW, this amp can be easily turned into a direct box amp or a stompbox by using the following dummy load design.  Simply use 8ohm as the dummy load (instead of the 4ohm in the diagram). 1/4 watt resistor should be more than enough for the 8ohm dummy load (as the amp pumps out 31mW!).
http://amps.zugster.net/articles/direct/index.html
Enjoy!
Stephane.
smashinator
That is super cool.  I've got to wait until after xmas to start building mine.  IT'S KILLING ME!!!!!
People who say it cannot be done should not interrupt those who are doing it. - George Bernard Shaw
http://pizzacrusade.blogspot.com/
aron
