Transistor question...
Started by O, January 03, 2005, 10:37:11 PM
O
I found some transistors and I wanted to see if someone knew what pedals I could build with them. These are the numbers...
2n2905a 8018
2n2219a
2n6027
So? are these just junk?
Joe Davisson
toneman
thanx 4 googlin' Joe.
keep on chooglin'
O
I read those, Joe (clear as mud to me :( )... I was just wondering if anyone knew what effects could be built around them.
Gen purp low power Si...good for whatever Si switching/amp application most likely, except High Gain/low noise, Maybe measure the Hfe, then use socket to test it.
 2N602x...unijunction transistor, I've never used or studied these...anyone else.
