1n34A diode
Started by ruimacao, January 07, 2005, 09:47:06 AM
ruimacao
what are the similar diodes ? for 1n34A .
Can i use OA81 to replece it ?
And what´s the diference : 1n34, 1n34a, 1n34n....
thanks.
loop box pedal
Gladmarr
These are really cheap, I've used a bunch of them in a distortion I'm working on.  http://www.circuitspecialists.com/prod.itml/icOid/567
Otherwise, a lot of suppliers have a cross-reference function in their online catalogs.  You can also look at datasheets for different Germanium diodes to see if most of the important characteristics are similar.
...sorry that doesn't directly answer your question.
SiCKNeSs
Quote from: ruimacaowhat are the similar diodes ? for 1n34A .
Yes,  OA8x, OA9x, OA1xx, etc are goods  :wink:
Hal
most germanium didoes are interchangable.  They might sound slightly different, but should be similar.
littlegreiger
What circuit are you making with the 1n34a's?
ruimacao
Quote from: littlegreigerWhat circuit are you making with the 1n34a's?
the jawari pedal
loop box pedal
