TS5: How to make it true bypass?
Started by hilbi, January 17, 2005, 06:53:43 AM
hilbi
I'm going to rehouse a ts5 in a new box , now I need to know how to make it true bypass, does someone know in detail what to do?
hilbi
Built so far: PNP FuzzFace, MXR Dynacomp, EA Tremolo, AMZ Mosfet Boost, AMZ Super Buffer, Blue Magic, Peppermill, RM Axis Face, Sparkle Boost, BSIABII, ROG Ruby, AMZ Mini Booster, MXR Phase 45 Univibe, Tremulus Lune, Dallas Rangemaster, Ross Comp
Jehle
I'm still a noob here, but I'm sure that this has been covered.
Check this link for more information than you can shake a stick at...
http://geofex.com/Article_Folders/TStech/tsxfram.htm
hilbi
I already read "the technology of the tubescreamer", i was asking if some one had a little more detail specific for the ts5.
hilbi
TheBigMan
Unless you use a massive enclosure you'll have to trim the board.  It's too big for a 1590BB.  Anyway, to make the pedal always on remove Q1 and Q2 and jumper the pads where the drain and source of Q2 were.  That's the two outside pads.  Now that the pedal is always on you can wire it for TB in the normal way with your new input and output jacks mounted to the new enclosure.
hilbi
hilbi
