Questions about GeoFex switching article.
Started by william, February 08, 2005, 06:25:16 AM
william
I'm trying to switch remotly between a few effects using a handfull of VTL5C1's that I have.  I was thinking of using the switching from an amplifier, but the schematic I have seems to be wrong.  I remembered seeing the GEOFEX document to do this and re-reading the article I uderstand how the CMOS is used, but am unsure how to power the output of the CMOS for the LED's of the VTL5C1's.  I have a preliminary schematic and would appreciate if someone could take a quick look at it for obvious errors I have missed.  I'm still learning much about electronics and sometimes miss things.
Also I'm unsure of what transistor's might work well.
http://216.250.178.122/will/web/repswitch.gif
Nikolay
First connect 1k resistor to current control to every led
second, connect 10k resistor between gnd and LE
This is all ;)
