Interesting find - any info/suggestions?
Started by mlabbee, January 30, 2005, 03:19:29 PM
mlabbee
I recently bought an old Multivox MXD-5 Analog delay - I can't find any information about the unit.  It sounds pretty funky and can go into this pretty wild oscillation - definitely an interesting toy.
Has anyone ever played around with one of these?  Any suggestions for mods?  I noticed it has a ton of JRC4558DX 0302 in it - I was thinking about pulling them and replacing them with some Burr Browns to see if it cleans up the sound at all.
It also has aMN3005 - the datasheet I found on it says it's a long delay BBD.  There are two motorola M_14049 - I can't see the chip very well, so I'm not sure the exact designation.  I found a datasheet for a MC14049 Hex Buffer - would that be a part you'd find in a delay?
puretube
yes - (CD) 4049 - clock oscillator/driver...
strungout
Hmm I saw that schemo and I was wondering what that CB1405 chip was? Any clue? Can't find a datasheet...
"Displaying my ignorance for the whole world to teach".
"Taste can be acquired, like knowledge. What you find bitter, or can't understand, now, you might appreciate later. If you keep trying".
puretube
obviously some VU-meter similar to the ULN2003 (?) family series
(IMHO not neccessary for audio-functioning...)
Peter Snowberg
ULN2003 is a 7 transistor NPN array with internal clamping diodes. I used to use those for lots of stepper motors. ;)
Look at LM3915 for a different chip with similar function (10 LED output). You could also replace it with an LM339 and a series of resistors (4 LED output).  :D
Eschew paradigm obfuscation
puretube
:oops:  :oops:  :oops:  I knew, I had to place that questionmark above:
I`s thinking of: UAA180 ( & UAA170 (?))
shudda looked in my stashbox before posting...
:shock:  :roll:  :?  -sorry-
analogguru
