Unidentified transistor
Started by michael_krell, February 07, 2005, 11:51:09 PM
michael_krell
I am fixing a AT small diaphram condensor and I located the problem to a transistor. It says K660 H96M on it. I cant find any info on it anywhere. Does anyone know what this is and what can replace it?
Dan N
A lot of 2SK fets just skip the 2S part. Try 2SK660?
Good luck!
michael_krell
michael_krell
Do you know where I can find a replacement, or find something to replace it with?
Paul Perry (Frostwave)
www.ee.nec.de/_pdf/D10753EJ2V0DS00.PDF
That's the data sheet, if anyone wants to suggest an equivalent.
The main thing is probably the low capacitance. But I suppose anything the DIY microphone guys use would be OK.
michael_krell
Thanks but i have already seen that. WIll any J-Fet work?
bioroids
Hi!
I don't know about the Jfet, but I can tell you don't ever touch the diafragm!
Luck
Miguel
Eramos tan pobres!
michael_krell
duh,
the mic is a Audio technica 3528 i have 4 of them, they are incredible
