compressor schematic
Started by zeppman, February 23, 2005, 12:28:00 PM
zeppman
Does anyone have a schematic of the robert keeley compressor?
MartyMart
No
What I can tell you is that its based on the "Ross" compressor.
Tonepad has a Ross/Dyna comp circuit - very nice too !!
Marty. 8)
zeppman
Marty-
I built that clone and have been having a lot of troubles with it. At first it was very very noisey. I went back and tried to fix it and now it won't work at all. What's strange is all the IC voltages are the nearly the same as what the guy from "fuzzcentral" posted for his clone. Do you have any advice (it sounds like you built one yourself)?
MartyMart
Hi zepp,
now I understand your PM !
I built a straight :dyna-comp" and had no problems, so I can't help much!
could just be a wiring error, did you use an audio probe ?
Marty.
j0shua
Hi Zepp :
You can build a Orange squeezer compressor , it's easy and very good sustain , you can ajust your taste whit the trim pot.
