Fuzzy EA tremolo
Started by LivingDeadPunk, February 25, 2005, 05:39:42 AM
LivingDeadPunk
Hi,
I've built the EA improved tremolo from GGG, it "works" but the output is a bit distorted and fuzzy especially if I plug it in a solid state amp, it sounds like a soft fuzz with a tremolo :twisted: two effects in one box :wink:  I should be happy... actually I'm not; with a tube amp the distortion is less noticeable but still present.
I've used these transistors: Q1 2n3904, Q2 2n5088, Q3 & Q4 2n5457 as specified in the schematics.
I measured these voltages:
Q1
C 8v
B 8v
E 8v
Q2
G varies
S 9v
D 9v
Q3
C Varies
B 9v
E 9v
Q4
G 0v
S 5v
D 9v
It is my first pedal with more than one transistor and I'm a little lost, moreover I've never listened to a EA tremolo so I d'ont know what sound I should expect.
Is it normal to get a kind of small boost with this box? If so, what tremolo pedal should I build to get a very clean sound?
If not:
I use two guitars an Ibanez with Di Marzio pickups (humbuckers) and a Strat with Seymour Duncan pickups (humbuckers but single coil size), could the pickups be too hot for the box?
What should I change in the circuit to stop it overdriving?
Could it be a problem with the capacitor?
Should I replace some resistors with others with bigger values, and which ones?
Technological progress is like an axe in the hands of a pathological criminal.
Albert Einstein
maximee
are you sure you don't have your volume pot cranked on the EA?
I built mine and it sounds very nice and clean, although i can give my signal a very strong boost when i crank up the volume pot on my trem...
(don't you love the pulsating LED? :) )
LivingDeadPunk
Well, when the volume is cranked the boost is stronger but even when it's set to, let say, 8 o'clock there is a small fuzzy boost.
I've used a 25k pot for volume, what's yours?
Do you use a tube or solid state amp?
I haven't tried the pulsating LED, it's only my third effect (after a  Rangemaster and a Lofomofo) and I tried to build it as simple as possible, I think I'll do that later when everything works, because it DOES look cool.
Albert Einstein
maximee
Ok, as I said, mine is clean with Volume down one my Hiwatt tube amp as well as on others...also on my 15 watt practice piece-of-sh...
I don't remember what pot I used...currently I am at work, so I can't look it up right now. I don't think your problem is your volume pot though...
Sorry I can't help you for now...
LivingDeadPunk
oh, don't worry it does help, if yours stays clean even with a 15watt crappy practice amp and mine doesn't there is a problem, I need to find what it is now... And that should take some time.
Albert Einstein
maximee
soon the guys from "over-there" will wake up again...
they will help you for sure...
alors, á plus tard...  :wink:
LivingDeadPunk
I hope so  :)
Tschüs
Albert Einstein
new_winter
hey man... the trouble is:
2 resistor R3 & R4
change the value of R3 (82K) >>> 150K
change the value of R4 (15K) >>> 4K7
I did have the same trouble, I just change this Rs & super!!!
saludos
LivingDeadPunk
Ok gonna try this
Thank you mate
Albert Einstein
Transmogrifox
I know this is OT, but I like your signature LivingDeadPunk.  Einstein had a lot more good to offer in wisdom about technology than all of his scientific progress.  That is the way of human nature, is it not?
To your EA trem problem, sounds like you got the answer.  It's just a gain/bias problem.
trans·mog·ri·fy
LivingDeadPunk
To Transmogrifox:
It is indeed. I was quite surprise to find that actually Einstein was a "philosopher" as well as a brilliant physicist, I've found a lot of quotes on the internet and even though most of them may be understood as jokes they convey much more than that; I may have a link with his most famous quotes in case you're interested.
Albert Einstein
LivingDeadPunk
Just checked and R3 and R4 are already 150K and 4K7, as specified on GGG layout, I don't understand what's going wrong  :shock:  ...
Should I lower R4 value and increase R3 ?
Albert Einstein
Transmogrifox
double check your connections and your build according to the schematic.  It sounds to me from the voltages you provided that you have part of the circuit connected in reverse.  you should see something close to 4.5 to 5.5 V on Q1 collector, a few volts on the base, and .7V less than that on the emitter.  The JFET should be referenced to ground according to the schematic, so there's no reason there should be 9V on the source and drain...
so check what you're doing and make sure it's all consistent with the schematic.
trans·mog·ri·fy
LivingDeadPunk
I've decreasedd R4 (connected to Q1 collector) to 2.2k instead of 4.7k and replaced Q4 and it works perfectly  :P
Thank you all for your help
Albert Einstein
onboard
Fantastic! Nice sounding trem, eh?
Incidentaly, I have the link to the original Electronics Australia article - is it ok to post it (the link, not the article)?
-Ryan
"Bound to cover just a little more ground..."
LivingDeadPunk
Very nice indeed, very Radiohead, with a delay it's awesome.  8)
Go ahead, post the article, I'm looking forward to read it
Albert Einstein
