"TyteWadd" strip board update.....
Started by MartyMart, March 05, 2005, 08:40:49 AM
MartyMart
For those who have seen "Dragonfly"s stripbaord layout ( which sounds great BTW ) here's an update for the circuit:
There is room top left on the board to add the following:
one 100uf power filtering cap, between the top strip "+9v" and bottom strip "ground"
Then also a 1N4001 diode , reverse power protection from top strip "+9v" also to bottom strip "ground"
Easy, quick filtering and protection !!
Andy, perhaps you could add it to your diagram for an update ?
Cheers,
Marty.
Dragonfly
Quote from: MartyMartFor those who have seen "Dragonfly"s stripbaord layout ( which sounds great BTW ) here's an update for the circuit:
Cheers,
Marty.
I can do that ! Great idea Marty  :)  thats one of the good things about using stripboards, as well as not packing the components on there super tightly...leaves lots of room for mods, and usually its just a simple matter of soldering the new components in place, instead of having to dismantle half the circuit !
Andy
