Jawari question (hey Dean, help!!)
Started by inverseroom, March 27, 2005, 06:31:19 PM
inverseroom
I'm building the Jawari and there seems to be no indication of how the transformer should be properly oriented on the board.  Which side is the primary?  I assumed the right, when you're looking at the layout, but since the test run didn't work I think maybe I'm mistaken.
Forgive me if this is dumb, I've never built stuff with a transformer before.
(BTW, I'm putting the Jawari and the Green Ringer in the same box and calling it the GREEN JAW!)
inverseroom
Hmm, just found it on Charlie's site.  I did it right.  Troubleshooting time!
However, once I've got it down, I'll post samples of the two in glorious series.
Dean Hazelwanter
Actually, *Primary* should be on the *left* side - towards the input, when using my layout of Tim's circuit, and a 42TM018 transformer.
HTH!
moosapotamus
I recall trying the transformer both ways when I built the Jawari and it didn't seem to really make any difference. It's a 1:1 transformer (10K:10K), so why should it, right? 8)
~ Charlie
moosapotamus.net
inverseroom
Quote from: Dean HazelwanterActually, *Primary* should be on the *left* side - towards the input, when using my layout of Tim's circuit, and a 42TM018 transformer.
HTH!
Hmm...I'm at work, but I'll go home & check it out later.  If Charlie's right, though, why should it make a difference?
Dean Hazelwanter
Doh! I just pulled out my PCB and took a look, without actually checking the schematic. :roll:
Charlie's right!
inverseroom
OK!  :D   Well, it could be that there was a grounding problem when I tested it, because the whole thing was dangling half-in half-out of the enclosure, and at one point there were actual sparks.  So I'll get it all tucked away happily and try again tomorrow!
moosapotamus
Quote from: inverseroom...the whole thing was dangling half-in half-out of the enclosure, and at one point there were actual sparks.
Cool!!
Well, uh... that's probably not good tho, huh?  :D
~ Charlie
moosapotamus.net
