How do you mount stuff inside enclosure?
Started by Ringwraith, April 04, 2005, 03:29:26 PM
Ringwraith
For the metal screw & holder for mounting boards, should I use a glue gun or contact cement? Also for the battery clip?
thanks
Sean
dpresley58
I usually use an epoxy for the standoffs that mount the board. Lately, I've tried the HotStuff medium-viscosity superglue and it seems to work fine. For grounding and clip mounting, I'll drill and tap holes in the base of the enclosure and mount them with small screws. The drill bits and taps that cut the threads can be found at Home Depot or Lowes. The holes are covered by the mousepad I use for the rubber skidproofing on the bottom.
Little time to do it right. Always time to do it over.
inverseroom
Lately I've just been using puffy double-stick tape!
phillip
I've been using the same method as inverseroom with my 1590B builds.  The inside of the B is fairly tight, so I stick the circuit board to the backs of the pots using double-sided (foamy) tape.  That stuff is super sticky and it isn't likey that the board will come loose any time soon ;)
Phillip
dpresley58
Oh, yeah.... (muse)
That stuff from 3M with the green tape...? I've used it to temporarily mount routing templates for guitar making, but didn't even think about it for stompboxes.
NaBo
Ringwraith
Thanks for the responses dudes.
Tape sounds great but what if you need to fix something?
Does the board peel off ok?
Also seeing how I have the metal stand offs already,
I'm wondering what the best method of securing these are.
Also the battery clip. I guess I could use the padded tape for the clip.
Sean
phillip
Quote from: RingwraithThanks for the responses dudes.
Sean
They peel off pretty good.  You might have to do some rubbing with your fingers to get any leftover adhesive to "roll" off the bottom of the board.
Phillip
KORGULL
QuoteAlso seeing how I have the metal stand offs already,
Try JB weld.
Attach the stand-offs to the board (with your screws/nuts,etc..) then apply the epoxy to the bottom of each stand-off and stick the whole thing in the enclosure wherever you want it to stay.
