clm6000 replacement for VTL5c2 in tremulus lune?
Started by bryantabuteau, April 06, 2005, 11:15:36 PM
bryantabuteau
can i use the clm6000 I have lying around as a sub for the VTL5C2 thats specced in the tonepad tremulus lune layout?  Will I need to tweak the circuit to accomodate it?
aaronkessman
according to http://www.geocities.com/CollegePark/Library/1355/clm6000.html
the rise time is good - 3.5 ms, but the decay time seems high - 500 ms!
you might be ok. try it out. The circuit it probably a bit flexible. there is a lot of gain to be had in that second opamp, and the speed range is HUGE.
I used the Silonex 5152 from Small Bear with an LED - made my own photocell. Works great, and its $1.75 or so.
but yeah, should be pretty flexible.
HTH.
Aaron
Samuel
bryantabuteau
thanks guys.  I will go and perf it up and see how she sounds.
