DSE/Jaycar PreChamp kit mod ideas
Started by evilpaul, July 23, 2008, 06:35:44 AM
evilpaul
I picked up one of these kits ($4!) recently with a view to modding it for guitar purposes .I'm hoping to achieve something fairly fuzzy-sounding, but as long as it sounds good, anything along the overdrive-distortion-fuzz spectrum will be satisfactory.
I've socketed the trannies (of course), so any interesting ideas for alternatives would be nice.
Here's the original schematic, and my basic mod ideas.
I swapped the 100k pulldown resistor at the output with a pot, to act as a volume control.
Instead of changing the gain from 23 to 101 by changing the 2.2k resistor to 10k, I could substitute a 10k pot. The potential problem with that is that it will effect the 48kHz low-pass filter and at 10k, it will be rolling off frequencies above 10.6kHz. This might not necessarily be a bad thing, since I'm assuming there will be more distortion along with the higher gain, rolling off some of the top end might smooth it out a bit.
The 22k collector load resistor is described in the documentation like this "... although not strictly necessary, it helps to linearise the output and significantly reduces distortion.", so I figured I'd sub it with a pot and see how it sounds. I'm not 100% on the theory behind how it works though, so if anyone could expand on it, it would be appreciated.
Other ideas:
The 22uf electrolytic cap in series with the 100ohm resistor at the emitter of Q1 sets the lower frequency response to 72Hz. That's low enough for a guitar tuned to drop-D, but not low enough for bass. What kind of bass attenuation usually gets used to prevent 'farty' sounding bass?
Caferacernoc
Actually, 72hz is practically full range. Many pedals cut bass off much higher than that for a "tighter" sound. You might also put some clipping diodes to ground right before the volume knob for some extra distortion.
