Strange hum on DoubleD
Started by RDV, September 24, 2005, 12:45:20 PM
RDV
I built this(DoubleD) last year and sort of gave up on it. It has a crazy hum that occurs(on both channels) when either gain is turned below about 10:00 and above 11:00. I've rebiased the JFET in front to half the supply with a trimpot, but that only helped the overall sound and sustain. I've also gone through the circuit and checked component values and connections, but the cause has eluded me. There's only a small range on the high gain(Bounce) channel that can be dialed in without this hum occuring. I have also tried different chips.
Any Suggestions where to look next would be greatly appreciated. ??? ???
RDV
RDV
It seems a bit like a ground loop noise that occurs when the gain pots are shunted to ground. HHMMMM.
RDV
