Wah Modders - socketing the inductor ?
Started by LoudGreg, May 01, 2005, 10:37:49 AM
LoudGreg
My question is would this be a good idea if I want to be able to switch inductors whenever I want to without re-sodering. A crazy idea I have is to hook up the TDK, Fasel, & Fultone inductor to a rotary switch so I can simply have all options at the turn of a knob. (just an Idea so far ..) :?
Another question would be, I put the true bypass switch in my Thomas crybaby. Now I want to increase the volume by changing the input resistor. Being new, all these resistors look the same to me !?! Is there any way (or lable) to tell me which is the input resistor ?
I'm new to modding effects and I'm learning very slowly about what all the parts are and what they do. This site so far is the best one for newbie's.
Guitar player not a tech............
Fret Wire
General Guitar Gadgets has a layout for switchable inductors
http://www.generalguitargadgets.com/index.php?option=content&task=view&id=112&Itemid=158
Great sites on wah mods and what they do:
http://homepage.ntlworld.com/s.castledine/greenfuz/wah.html
http://www.geofex.com/Article_Folders/wahpedl/wahped.htm
The "volume" resistor is 68k, drop it to 47k and you should be all set. The stock 68k should be blue, grey, orange, and gold/silver.
Here's a resistor calculator to help you identify resistors. Use a magnifying glass, check the colors on your board, and plug them into the calculator. The first three bands denote the value, and the fouth band (silver/gold) denotes the tolorance range. This calculator is for carbon comp/film, 5 & 10% tolorance resistors.
http://www.dannyg.com/examples/res2/resistor.htm
Fret Wire
(Keyser Soze)
radio
Hi
you might want to search for fasel (red or yellow) not only here
but in google too. I think it s feasable the way you described it
but is there a possibility of interference betwen the 2.
That s a point I don t know!!
The difference should be highly noticable
Greetings JMErnzer
Keep on soldering!
And don t burn fingers!
Fret Wire
Quote from: radioyou might want to search for fasel (red or yellow) not only here
Aron sells the yellow fasels for a great price right here. The GGG inductor rotary switch layout works fine, no interference.
http://www.generalguitargadgets.com/diagrams/wah_mod_lo_rotary.gif
Fret Wire
(Keyser Soze)
Pedal love
Quote from: LoudGregA crazy idea I have is to hook up the TDK, Fasel, & Fultone inductor to a rotary switch so I can simply have all options at the turn of a knob. (just an Idea so far ..) :?
Well this idea isn't all that crazy, the only thing is will you have enough room for that many inductors?pl
