ABY switch - buffering in and out?
Started by ethrbunny, May 14, 2005, 07:50:30 PM
ethrbunny
Im building an ABY box. I plan on buffering the inputs with an op amp follower. Is there any reason to buffer the output as well? Is there any reason not to?
EDIT: also - given the v high resistance of the op amp - what value would I use to determine the input capacitor?
--- Dharma Desired
"Life on the steep part of the learning curve"
Basstyra
I don't see the point in buffering it, so I think I wouldn't. The input buffers would give the  low output Z needed.
You would just wire switches, after the buffers, aren't you ? Switches and wire. So at the output, you'll see the input buffers.
But I can't assure you I'm right.
The best french bass-related forum : http://forum.onlybass.com
A french DIY forum : http://www.techniguitare.com/forum
My work (stille only in french, sorry ! ) : http://perso.wanadoo.fr/jumping-jack/atelier/atelier.html
ethrbunny
My rationale behind buffering the output would be to prevent another effect or amp from 'leaning' on the CD4066.
Yah, its probably overkill.
--- Dharma Desired
