Millinieum Bypass
Started by wui223, May 15, 2005, 06:35:30 PM
wui223
I worked out the bypass circuit, but it doesnt work, the LED didnt lid why? I use BS170 for FET and 2N3904 with emitter left open for the low leakage diode. What are the value of limiting resistor for LED should i use?
KORGULL
Something like 1K - 4.7K should do for the current limiting resistor.
Double check the Millennium's connections to +/-  power and the connections at the switch.
If you're using Millennium 2, do you have the second, regular diode (1N914) in there?
wui223
Yes i double check already. everything in place but no light.
darren
Take a deep breath, and triple check.  8)
check for solder bridges.
Desolder the LED, check it works.  Measure the voltage at the LED anode, make sure it's 9V.  download the datasheet for the mosfet you'reusing, check you have the legs the right way round.  do the same for the 2n3904.  swap out the mosfet, maybe it got fried.
telling me you double checked everything doesn't help cos clearly it doesn't work so you missed something!!!!   ;)
measure the voltages everywhere and post em so we can pull it to bits.
good luck...
darren
wui223
i got the light already but i modify the circuir 8) i disconnect the low leakage diode (2N3904) and it works. WHY?
wui223
How to improve the brightness of LED ?
TheBigMan
Change the limit resistor if the LED brightness isn't what you want.  Lower the value to brighten it and vice versa.
