Sparkleboost problem . No boost
Started by pnak, May 30, 2005, 04:54:00 PM
pnak
Just finished sparkleboost. Subbed J201 for a mpf102 other than that
its all up to spec. plug in and volume and gain controls work
but has no boost. top volume same as the amp. drain voltage at 4.5v
and went over it several times. could it be the mpf102?
Bagge
It could be the mpf102; try to replace it. Sparkleboost should have some boost, although from other threads it's stated that mpf102 has less gain than j201 and nte458.
http://www.diystompboxes.com/sboxforum/viewtopic.php?t=29075&highlight=sparkleboost+mpf102
This is also a good thread to read:
http://www.diystompboxes.com/sboxforum/viewtopic.php?t=29507&highlight=sparkleboost+mpf102
It could also be some resistance, e.g. bad connection, wrong/bad resistor. In the second thread, I believe there are some voltage readings. You could double check there. Good luck.
B.T.W. This is a fantastic circuit. :D
pnak
Thats a great link, and i have read threw it but still havent
discovered my problem. Im gonna go threw it again and if I cant find
anything Im gonna wait for my J201 to come and change it out
pnak
wired in a dpdt switch and plugged into the rest of my chain and did notice
some boost. maybe a few db's but the clarity and tone it gave my rig
was  very noticable.nice pedal . should I expect more volume with the
j201 because I built this thing hoping to use it as a leadboost with my
cover band and the mpf102 just aint giving it any boost.
squidsquad
I believe the NTE458 is reccomended...and watch for a pin out difference.
Also...trim the bias by ear...it can vary have a small sweet spot.
pnak
I cant seem to find a source for a NTE458 can any body
suggest site
