Vertical Mount PCB Pot Search
Started by MarshallPlexi, June 01, 2005, 05:54:52 AM
MarshallPlexi
Guys I've been hunting down a series of pots I can use on some upcoming projects and I can't seem to find it in a suppliers catalog. Here's what I'm looking for.
9mm or 12mm or 16mm Size
1/4" Metal Shaft
Metal Bushing
Vertical Mount PCB - (pins are in line with the shaft)
Preferable a "snap in" mount.
Good selection of, Audio, Linear and ultimately Reverse Audio tapers.
I know that Alps and Alpha make a pot like this, but Mouser doesn't have the values that I need and I can't afford to custom order a group of pots.
Here is the Alpha pot that I've found:
http://www.alpha-products.com/cd_catalog/Pots/p39.htm
Here are the Alps pots that might work: Series Rk09L and RK117L
http://www.potentiometer.com/alps_rotary.cfm
Please let me know if you know where I can find the pots that I'm looking for.
gez
I use Omeg pots and bend the pins (can support a lot more weight than the little purpose built ones).
Cheap and cheerful solution. :)
Paul Perry (Frostwave)
Farnell carry some of the Alps PCB mount snap-in pots.
MarshallPlexi
