ABY volume problem
Started by ESPguitar, June 02, 2005, 10:15:10 AM
ESPguitar
Hi,
i made a aby box today..
It was noisy like hell on the channel i didn't use.. So i inserted a 1,2M resistor from Ato ground and from B to ground..
Now it's almost no signal left.. What shall i do?
Thanks,
Robin
LyleCaldwell
Take the resistors out.  Wire the switch so the unused channel is grounded out.  See Mike Fuller's example at fulltone.com.
What does this button do?
psionicaudio.com
ESPguitar
Yes,
But if one output is grounded, it will ground the outs when i use both outputs..
RB
Andi
