drill templates
Started by strangegrey, June 10, 2005, 10:54:58 PM
strangegrey
I know there's a drill template for the BB chassis on GEOFEX.....
does anyone know if there's one out there for a B size (mxr) chassis...?
Thanks,
Frank
brett
Templates do make life much easier.
Here's what I did.... I got a piece of flat aluminium, about 80mm wide and 150mm long (I use the "Taiwanese" boxes).  I bent it so that it fits snugly on the top and along the sides of the box.  I decided where I wanted holes and drilled pilot holes (1/8") in the template.  Now it takes about 5 minutes to drill all of the pilot holes needed for a box.
good luck
Brett Robinson
gez
This software (thanks Mike!) can be misused to make your own templates.  Simple to learn and it's in inches.
http://www.frontpanelexpress.com/download/index.htm
